RCU Forums - View Single Post - Bad needle valve?
Old 05-21-2005 | 05:20 PM
DaveB
Default RE: Bad needle valve?
I think I would wait for a new needle. If you go lean while flying for some reason, the engine would be damaged very quickly. Having said that, you may want to take a closer look and see if you have an air leak somewhere. Perhaps around the fuel line or the needle fitting. A leak will cause a lean needle setting.
DaveB
