RE: TT 91 4C Problem ... HELP!!!
Thanks guys, will look into the timing. Oh man ... I removed it the choke unit, I will install that again. You guys are great.
Just a question, not about the top end only but the carb is open 50% just to idle. What could be the cause of that? Might it be that the low end is too lean? But the transition is smooth.
