RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 05-22-2005 | 07:27 AM
  #2352
goldenclan
Default RE: U-Can-Do 3d 46?
northwing. Have a question about the prop nut, is there 2 of them? If so, your engine is running too lean and is backfiring. That is what is causing the prop nut to loosen. A four stroke back firing like that can cause some damage to the engine and the prop and the spinner. Check you high speed and your low speed needles. How much for the funtana?
