RE: TT 91 4C Problem ... HELP!!!
Put the piston all the way up. One time when the piston is all the way up, both valves should be open. If this is the case, turn the crankshaft one full turn until the piston is all the way to the top of the cylinder again. This time the dot on the side of the gear just beside the oval cam should be straight down.
When the engine is at idle, does the engine run slow enough for you?
