ORIGINAL: bassfisher
On a "normal" tank you have one line that goes to the carb and one line (the pressure or vent line) that goes to the muffler. You fill the tank thru the carb line. If possible, disconnet the "vent" line from the muffler. When you tank is full, you will have fuel come out the vent line. The reason for no "flip" tops is that the fuel tank is normally enclosed inside the fuse. Plus the airplane tank is sealed at the stopper. Cars normally do not have the same duration of different pitch attitudes that planes do. Also, teh vent lien is normally connected the brass tude that has an upward bend to teh top of the fuel tank. The carb line should have a clunk on the end. Do not mix the two lines up, or your engine will die from fuel exhusation once the fuel can no londer be pulled through the vent line.
Bassfisher,
thanks so much for your tips. Where exactly do you place the fuel tank? I notice a space right behind the engine? Is there a strap kit to keep the tank from floping around, or do you jam foam around the tank? The movable flaps on the wing (alerions?) are they designed to work simoultaniously, in the same direction, or do they work opposite each other? I have 2 separate linkages to those 2 flaps, but looks like only one servo operates them. All the other linkages seem to be pretty self explanitory. Thanks,
Rich
