RCU Forums - View Single Post - Clutch problems PLEASE HELP!
Old 05-22-2005 | 07:20 PM
ncgrunt
Default RE: Clutch problems PLEASE HELP!
Is the spur gear turning when you rev the engine?
If it is, look at the drive shafts going to each rear wheel. Are both of them turning?
-If one shaft is turning but the other one isn't then you probably have a broken roll pin in that axle (the diff is diverting all the power to that wheel since it's the path of least resistance).
-If neither shaft is turning then the problem has to be inside the transmission, most likely a stripped gear.
