RCU Forums - View Single Post - Brison 2.4 Mid-range
Old 10-04-2002 | 03:31 AM
rctom's Avatar
rctom
Default Re: Brison 2.4 Mid-range
Originally posted by smartwork
Although I've tested in several places, I've got the low needle just a little richer than max lean - judging from the "acceleration test" when setting the low.
What exactly is this "acceleration test". The engine sounds like it is still rich on the low end. IF you can make the low end leaner with no other ill effects, that will probably help clean up the transition.
TF
