Dave, sometimes the fill line over time needs to be chopped where you plug it. If it is sucking air, that is your problem.
The plug does not fit perfect forever.
Other than that, check the cap to the uat make sure it is tight. Also are all your lines safety wire??
That's about it, other than a pinhole in fuel line???
Good Luck
Sean
