ORIGINAL: seanreit
Dave, sometimes the fill line over time needs to be chopped where you plug it. If it is sucking air, that is your problem.
The plug does not fit perfect forever.
Other than that, check the cap to the uat make sure it is tight. Also are all your lines safety wire??
That's about it, other than a pinhole in fuel line???
Good Luck
Sean
Sean,
All good ideas. Yes the lines are safety wired. I'll check the UAT cap and fill line. The little alum plug "seems" to fit well. I'll report back this evening.
Dave Rigotti
