RCU Forums - View Single Post - Seamaster Mods
Old 05-23-2005 | 01:21 PM
manix
Default RE: Seamaster Mods
I´ll get an ARF ACE Seamaster to be used only on water. Ordering also a Satio .72 for it.
Is a 3 blade prop 12-6 the rec. one?
Will that size of eng require some reinforcements to the kit?
What hardware included in the kit shall I replace due to low quality? What should I replace it with?
Understand I need to reinforce the horizontal Stab, one flying wire each side enough?
Use full lenght velcro/servo tape for the small tip floats, use a golden rod for the elevator, or for all included rods? I must be missing many other things, could you help to continue my list?
Ahhh Tip floats... Remember reading to deflect them lat. some 5 deg. Which way? Front closer to the fuselage or the other way around? Any experience with that?
Many Tks.
