RCU Forums - View Single Post - Building custom fuel cells
Old 05-23-2005 | 03:20 PM
Gerald Rutten's Avatar
Gerald Rutten
Default RE: Building custom fuel cells
Sorry Seanreit, missed something out of a previous thread.....
Originally posted by Seanreit:
Vacuum moulds made with a homebuilt machine? How much to get into making those moulds roughly if I wanted to get into that? With that kind of device
This was done at my local hobby store where they are able to vacuum canopies and r/c car bodies. This vacuum mould is strong enough to mould several tanks out and very easy to make. Sure you have can find such vacuum machine at a local hobby store??
Shock, I use a simple conventional gasoline rubber stopper (I think from Dubro...?) and glued a mating aluminium ring in the fuel cell with epoxy/microballoons, (Also used for the seam) look at the first thread I mentioned. Most people said the micro balloons wouldn´t work, will start leaking, but with two models in action for 5 years now all tanks are still leak proof with no signs of brown colorisation in the flanges..
Best regards,
Gerald
