RCU Forums - View Single Post - TT 91 4C Problem ... HELP!!!
Old 05-23-2005 | 05:45 PM
Jazzy
Default RE: TT 91 4C Problem ... HELP!!!
tIANci,
Glad to hear you got her runnin'!!
You do realize that you have to remove the rocker arms to be able to remove the cam don't you?
With the pushrods under pressure it cannot be done.
I usually remove the entire head. That way I can clean the valves and combustion chamber.
This does not affect the valve adjustment.
Good Luck,
Jeff
