I would suggest using silver solder as it needs a higher temperature to melt (thus your engine exhaust heat will not melt the solder especially a four stroke) copper tubing is great for this job but when i t comes to the the exterior bit try using brass tube as it is lighter i have a magazine somewhere that has the guide to doing this will look it out and scan it in for you
