RE: TT 91 4C Problem ... HELP!!!
The TT .91 four stroke will run nicely on the bench without the choke. But, unless you are running a pump, in the air it will lean out at about 3/4 tank and deadstick. It may also run without the choke if you do not open the throttle fully.
