RCU Forums - View Single Post - When should hinges be installed???
Old 10-04-2002 | 12:46 PM
LuvBipes's Avatar
LuvBipes
Default When should hinges be installed???
I also use Hobart Hinge Points and find they work very well. I'd recommend you PREPARE all the hinging before you cover/paint the plane, but only glue the hinges in AFTER the finishing process is completed. That way, you can more easily fill/sand/paint the control surfaces while they are still free.
