ORIGINAL: bobbykokinos
ORIGINAL: Deadeye
I have another question. I've gotten the white striping on and I started putting blue on. Well, I didnt realize the bottom of my sock had picked up some of the blue color and now the white stripe has blue smudges on it. Is there a way to get these off? I tried rubbing alcohol but it didnt work.
Trim solvent oughta do the trick.
I thought trim solvent was used to adhere two piece of monokote together..
It is. It is a solvent for the adhesive, which is also the color layer. There are two layers to Monokote. The clear plastic layer that is on the outside of the plane, and the colored adhesive layer that is inbetween the plastic and the plane.
