RCU Forums - View Single Post - *Modeltech Formula ARF 3D Competition 46-60*
Old 05-24-2005 | 05:59 AM
Xup's Avatar
Xup
Default RE: *Modeltech Formula ARF 3D Competition 46-60*
Some info for you,
The YT Formula has been available in the UK for a year, many are flying here.
My formula with a saito 91 running a Apc 15x4 , came out at 5lb 10 oz dry,
even with a 7 oz nicad tight to the bulkhead, to get a slightly
rear CG, the plane tends to come out tail heavy.
The plane fly's brilliantly and is very forgiving, very thick wing section.
Has masses of power, hovers well under half throttle.
You will need to use throttle manegment, on large engine setups.
Have very close to 200 flights on mine now, and it still looks new.
Good 3D setup would be the Saito 82 and a 14x4 prop.
