RCU Forums - View Single Post - Something Quick!
Old 05-24-2005 | 09:06 AM
HighPlains
Default RE: Something Quick!
It's rather stunning how heavy of balsa is used in some kits and ARF's. I had one kit of a Stik that had 18 lb density wood, not the kind of stuff I would normally use with a triple beam balance gram scale. Six to eight lb wood is what I try to use for most construction. The stik will likely need the bathroom scale with the 18 lb stock, wood that the Navy rejected for rafts.
I usually put lead into the rear crankcase cover if I am tail heavy (rare).
