RE: Cen st2
I'm going out on a limb here, but are you sure the starter box is turning the right way... It sounds like the starter box is spinning the flywheel the wrong way and loosening the shaft that holds the clutch bell clutch to the engine... To check this, look fron the back of the engine at the flywheel... It must turn counterclockwise or it will fall off...
