RCU Forums - View Single Post - Pull-Pull Rudder setup problem/question
Old 05-24-2005 | 03:53 PM
jlgrebe
My Feedback: (7)
Default Pull-Pull Rudder setup problem/question
I have setup a pull-pull rudder on a 37% Ultimate, and I have a question. Cables are tight on both sides when centered-- however when I start to deflect the rudder, the cable on the opposite side gets slack -- when fully deflected, the slack is very pronounced. My question: is this normal?
here are the details:
SWB self adjusting tray with offset bellcrank
Distance across the bellcrank is 2.5"
Control horn on rudder is 4" from end to end (using du bro HD 10-32)
The control horn pivots on the hinge line
Using cross over cables
Lenght of cables is approx. 30"
I want to know if I have done something wrong in my setup, or slack is normal in this configuration? This is the first time I have tried an offset bellcrank and cross voer cables.
thanks
Jim
