RCU Forums - View Single Post - Tensor 4D
Thread: Tensor 4D
Old 05-24-2005 | 06:27 PM
tylerman
Default RE: Tensor 4D
Edwin, If you are willing to spend the money you can get the best of the best (as you probably already know) I am running an AXI 2208/34, Jeti 8 amp, Thunder power 1320 mAH, and 730 mAH. It is straight up verticle with authority But like anything else in the world something is always wrong.
The bad thing about my setup is I dont have my prop size dialed in yet (as I just found out last night) Right now I am using a APC 10X3.8. My dad brought home his watt meter and I tested it all out. I have WAY too much prop. My motor is trying to draw way too much current from my little 730.
The 730 is rated for 7amps to9 amps to 13amp bursts. and at just above 3/4 throttle I was at about 12amps[&:]----I have been flying this plane with this battery for over 3 months now[X(] I am absolutely amazed my batt. hasnt blown up in the air. I am also amzed my ESC and motor havent burnt up all crispy and stuff yet.
The Moral of the story is go get a watt meter and a bunch of props[&o]
My tensors AUW is 11.32 ounces w/ 730
Good Luck!
