RE: Radio programming/ Flaperon
Hey Chad,
I forget which radio you bought. First thought is the rates; up and down not being equal in the transmitter.
Are the servo arms parallel to the trailing edge...ailerons when the TX sticks are neutral. Does anything bind, do you hear buzzing at neutral.
I probably need to read, I thought the superstar was a single servo wing, maybe this helps a bit.
Mike
