RE: Inserting piston ring
Well I'm officially screwed! I got the ring to compress and as I "helped" it back into the cylinder the ring broke and now the piston is stuck at the bottom of the crank case. Is it possible to remove the sleeve? Man, this is pitiful[&o]
