RE: U-Can-Do 3d 46?
Thanks Barry,
This will be my first set of floats. I'm looking to put them on a Nexstar with a OS 46 fx in it. I've been reading through other posts, and it looks like there are pros and cons to both prebuilts and kits. It also looks like the length and width of the float needs to be considered. Ultimately, I'm looking to get into something that will be quick and easy to build, and relatively easy to switch back to the wheeled gear. Is there a specific set that you can recommend? I would like to avoid something that is going to take hours and hours to build. What else should I factor into consideration when I make the decision?
Thanks for your advice,
v_twin
