RE: MOKI 180 LOW END PROBLEM!
what I did for my big Tigers and Saitos, is to buy an imperial drill bit sized just below the size of the engine shaft, and a straight reamer in the metric size of the shaft.... a drill press is required to get the hole accurate... check out your local machine supply house, or maybe Harbor Freight....
