RCU Forums - View Single Post - Pull-Pull Rudder setup problem/question
Old 05-25-2005 | 04:51 AM
FenceMagnet
Default RE: Pull-Pull Rudder setup problem/question
"I have to disagree. Having the bellcrank and the rudder horn the same size will offer a 1:1 ratio. It is desireable to set your system up with a 1.5:1 ratio giving "mechanical advantage" to the setup. I have mine set up with a 3" servo arm and a 4.5" rudder horn."
the setup you describe gives you mechanical "disadvantage".... slop is multiplied and torque is reduced...
