RE: Building custom fuel cells
I did the lost foam. To get the foam out I simply mechanically dug it out with a screw driver then melted out the last little bit that remained after the screw driver with lacquer thinner. It was easy and worked very well. As I've never had to take apart a main tank, I simply epoxied in the appropriate brass tubing for fittings. Worked very well.
