A guy at the field had a similar story with a band saw! His little girl yelled down and he was REAL lucky, only nicked his finger. Could have been a lot worse.
Do you have the link? I have seen a couple of things online. Even though from the pictures above looks like it is well on the way to being finished, there are a lot of things left on this plane to do. I have to redo some of the stringers since they are not perfectly straight. I have been adding CA to all of the joints to make sure that they are strong since some of them have been coming loose.
I have been out to the Spacewalker.org site and others to see the real one. There isn't a lot of pictures of real ones out there. Here are some of the links that I have found
http://www.spacewalker.org
http://www.warnerair.com/
Hope this helps
Lee
