ORIGINAL: por924
Ok guys, I figured out the problem, it was the throttle arm on the carb that was loose. Wow I'm glad I did not fly it that way. Now I have a different question. What did everyone with the big Mokis use to make a hole big enough for the tru-turn spinner adapter? I have been everywhere from sears to home depot and I can't seem to find the right size drill bit. Can anyone help? Thanks
The spinner backplate must be reamed out to 12mm. The Fox reamer has the right size. The Fox reamer did the complete job for me without a drill. I still used it in a drill press. Also, I found that I had to ream my props for 10mm and ream the back half of them 12mm. I don't know why Moki machined their shaft that way.
