RCU Forums - View Single Post - Using a bushing engine for a pusher?
Old 05-25-2005 | 02:49 PM
Rcpilot's Avatar
Rcpilot
My Feedback: (78)
Default Using a bushing engine for a pusher?
I know that it's not recommended to use a bushing engine as a pusher. The prop pushes the crankshaft assembly back into the backplate and quickly ruins the engine.
Would it be possible to buy a couple extra thrust washers and put them behind the drive washer. That would pull the crank forward enough to get it seated where it needs to run.
I know that when you set a bushing engine for standard tractor prop--the load pulls the crank forward and seats in against the rear side of the bushing.
Do you think it would work to put a couple extra thrust washers behind the drive washer to "adjust" the crank forward against the rear bushing seat in the pusher configuration?
