RCU Forums - View Single Post - Kingcat vs Hustler.
Old 05-25-2005 | 05:32 PM
  #69
erbroens's Avatar
erbroens
Default RE: Kingcat vs Hustler.
I don´t know if the bernoulli effect is the sole responsible for the turbine angle issue, this plane
has the elevator well above the jet stream, unlike the KC and the Hustler, and it needed too a small shim (you can see in the pic) to correct slight pitch changes with different throttle settings... I think that is more likely to be the plane´s force arrangement and its variation at different speeds.
Enrique
ID:	276448   Click image for larger version
