RE: Using a bushing engine for a pusher?
The crankpin should never touch the backplate on an engine that was set up properly from the factory, even when used as a pusher. Most bushing engines come with a thin steel washer behind the thrustdriver. This was fitted to reduce the wear when using an electric starter and should work effectively when the engine is used as a pusher. They are easy to misplace, so make sure that your engine has one in place.
