RCU Forums - View Single Post - MOKI 180 LOW END PROBLEM!
Old 05-26-2005 | 12:16 AM
NM2K
My Feedback: (14)
Default RE: MOKI 180 LOW END PROBLEM!
It sounds like something is restricting fuel flow. You are using large fuel line through out your fuel system, right? This can make a major difference on large engines.
If you are using the recommended large fuel line, I would disassemble the carburetor and look for a piece of dirt or flashing that could be restricting fuel flow. Good luck.
