RCU Forums - View Single Post - CG Adjustments/Problems
Old 05-26-2005 | 09:51 AM
britbrat
Default RE: CG Adjustments/Problems
I am a bit worried about the amount of lead required -- 3 oz is a lot more than I ever had to add to a Superstar to balance it with a BB 46 up front. Make absolutely sure that you aren't tail-heavy -- hiding the lead in the stab will make it a pain to get at if you need to remove some.
