ORIGINAL: flycfii
So.... would the effect of a too-long feedline be to make the engine run lean? That's my guess.
Yes. If it was sufficiently long, you couldn't get adequate fuel flow with the NV turned right out. However, as long as you can actually peak the engine, the line length will be OK.
