RCU Forums - View Single Post - Calibrate Your Voltmeter
Old 05-26-2005 | 02:54 PM
Rodney
Default RE: Calibrate Your Voltmeter
I'm afraid some of you are needlessly worrying about how the meter was calibrated. If it was calibrated by both reading the same voltage (makes no difference if the battery was loaded or not--i.e. a volt is a volt is a volt no matter what the load on the voltage source).
