RE: Aerobird challenges
FIXING WINGS AND TAILS
Repairing a CREASED wing with packing tape alone doesn't really work very
well. It works better on the tail because it encounters different forces, but
what I am about to explain works MUCH better on both the wing and tail and is
easy to do. It should also apply to the Xtreme, and all the Firebirds.
A creased taped wing might fly, but at the first real stress, its gonna fold
and you are going to crash. Tape alone has no body or stiffness of its own to
resist a fold since the wing's internal foam is compressed. Net Net, there is
nothing to resist the next fold. You need to stiffen and support the wing.
Here are things I have used for wings and the V tail with pretty good results.
Take a hobby knife or razor blade and open the vinyl covering at the crease or
stressed area
Get the wing set in the proper position, even bend it slightly the other way
to open up the gap.
Fill the folded area with Elmer's white glue or titebond yellow glue. I have
not tried Gorilla Glue, but that might work well. The white and yellow glue
will seep into the foam and bond with it and stiffen it.
Let it partially dry, at least 90 minutes, then fill it again. The first coat
will soak in. The second coat will fill the gap. Let it dry
at least 24 hours, then check it. If it is fully dried, apply a little clear
packing tape to help it resist pulling open.
Another approach I used for large folds, especially center folds is to bond a
thin but somewhat stiff strip piece of wood, like 1/32 ply, to the top of the
wing. You can use some contact cement or double sided carpet tape works well.
Then take a piece about 1-2 inches wide inch wide and at least 2 inch to
either side of the crack should work well. It is stiff enough to resist the
next fold, but will still flex with the wing. Then cover it with clear
packing tape stretched so that it forms a smooth finish with no sharp edges so
the air can flow nicely over the wing. You might not notice it at all. If
the repair is well out toward the edge of the wing, you may need to do the
same on the other side just to keep it balanced.
I have never had one of these fold. The bird can handle the weight of a light
piece of plastic or wood.
Embedded supports
If you want to get more aggressive, you can cut the covering on a new wing or
a damaged wing, remove or compress some foam and embed the plywood or a dowel
support piece into the wing and glue it into the foam with Elmer's white glue
or Titebond yellow glue. The wing does have to flex a bit. Then tape over
the top to cover it. I have not used this approach but I may try it if I
badly bend a wing.
While Epoxy is strong, it doesn't move with the foam the way Elmer's or
Titebond do so I have seen a tendency for epoxy to pull away from the foam
which weakens the area.
If you look at the Firebird XL wing, or the Aerobird Xtreme, they have a
support rod embedded into it when you buy it. Other similar planes, like the
T-hawk, have these supports in their wings when they are new. If you do this,
I suggest doing this so that is spans the body of the plane as many folds
happen where the rubber bands attach. Too often you make a hard off angle
landing on one side of the wing but see no damage to the wing. You think you
have a clean wing, but in fact the foam inside has been weakened. You fly and
the wing folds and you say "what happened?" What happened is 5 hard landings
ago you stressed this spot, compressed the foam enough to weaken it and boom
you have a fold.
Give it a try. The key message here is don't depend on tape to keep the
crease from folding again. Tape is good for closing up damage on the front or
rear edges of the wing and for reinforcement of a new wing by the prop area,
but it can't keep a creased wing from folding up again.
