ORIGINAL: foxy42
Don't need to actually change the shocks, just the oil, pistons and springs...nor the wheels, only the tyres...
This is what I'd do...
Change the shock oil all around for 60wt, and put the stiffest springs you can find that will fit. Add stiff anti roll bars front and rear, and run it as low as possible (about 5 or 6mm off the deck should be fine). Then put those on-road tyres on it (they even look like rally tread, but I can't for the life of me remember what they're called), with stiff inserts. It will handle like a train after that, you'll be traction rolling all over the place. Then fit a front one-way differential, lock the centre differential and/or fit a two speed. That should cost you some...
Then take it down to the local asphalt track and watch their faces when you roast the one 1/10th models through the twisties and leave them standing on the straight! Hahahahahaha....
Thanks for the info! I'd like to find a wheel/tire set (preferably pre-mounted) that will mount right onto the Super Athlete hubs. What brand fits on the Super Athlete. I don't know what the standard is, but I know the hubs are different than on my buddy's MP5. I'd also like to buy new shocks, what kind should I buy, Ofna? This way I could go back and forth between on-road and off-road without having to rebuild the shocks. On the final recommendation on the diffs, what kind of diffs can I currently buy that would fit into a Super Athlete?
Thanks again for all the advice!
