RE: need help
Sounds like your idle stop is set wrong. With the engine OFF, take off your air filter. Put on the brake, and look in the carb. There should still be a 1-2mm gap for fuel/air to go through. If it is completely closed you need to set the idle stop so that there is a 1-2 mm gap there.
