RCU Forums - View Single Post - Calibrate Your Voltmeter
Old 05-27-2005 | 09:59 AM
  #32
Rodney
Default RE: Calibrate Your Voltmeter
When you calibrate a meter, you are not measuring battery voltage, you are comparing readings from a controlled source. The battery doesn't come into play during calibrations. That controlled source can be a battery though as long as both insturments (the standard and the unit being calibrated) are connected at the same time.
