RCU Forums - View Single Post - Balsa USA Phaeton 90 Bipe
Old 10-08-2002 | 01:51 AM
pmuscutt
Default Balsa USA Phaeton 90 Bipe
Edwin,
Oops After writing the following I noticed you have no plans? You could order a set of plans.
With my 1/4 scale cub what I did was I laid the engine on it's side with the motor mount attached on the plans so the prop hub was lined up with the prop hub on the plans, then I marked where the engine mount was for the placement of the firewall, which happened to be 2" back in my case.
Patrick
