RCU Forums - View Single Post - Balsa USA Phaeton 90 Bipe
Old 04-24-2003 | 06:42 PM
  #78
RickT
Default Phaeton 90
On my Phaeton 90 as far as the cowl I used one from a Fokker DR1 a little wide so I made the fuse wider and rounded it off. Tapering the width down from the cowl to the cabaines.
I used the gear supplied and reinforce it by soldering cross wires to them.
I think i'll be going with the top wing at -1 degree, the bottom wing at +1 degree and the stab at 0 degrees, wing incidence.
the engine, Zenoah G26, i'm thinking of using 1.5 or 2 degrees down thrust and 1.5 or 2 degrees right thrust.
I think with a bigger engine I should go with the higher numbers, 2 down and 2 right?
Anybody have a way to figure this out?
Rickt
[email protected]
AMA # 23715
IMAA # 26601
