RCU Forums - View Single Post - Nylon Wing Bolts Easy Tip (Pencil Sharpener)
Old 05-27-2005 | 04:53 PM
bentgear
Default RE: Nylon Wing Bolts Easy Tip (Pencil Sharpener)
Villa, no telling how many wing bolts and body post I have cut off using a pair of side cutters, almost all of the time with good results. I have also sanded many, rounding/pointing the end for easier starting. If you will give the pencil sharpner a try, you might just find out you like it. If not, what have you lost?
Ed M.
Now that I think about it, if you sharpen it all the way down you get a true point. All the Nascar bodies I mounted over the years and a spare set of sharpened off body post would have made it so much easier. Where was this tip when it would have caused me to think of that!!!!!!
