RE: ENGINE CLEANER ?
You don't want to boil the antifreeze solution. Just hot below boiling temperature. I use the potporri type pot.
On a four stroke, to pull the covers (Backplate, Valve covers, Cam cover on a none Saito engine) and clean. Then you will need to flush it with a lot of thin oil like ATF Dexron/Mercon. Should be OK?
Enjoy,
Jim
