RCU Forums - View Single Post - First Scratchbuild--need help with airfoil
Old 05-29-2005 | 12:30 AM
Rcpilot's Avatar
Rcpilot
My Feedback: (78)
Default RE: First Scratchbuild--need help with airfoil
I don't know what type or number of airfoil it is. As I said. Very similar to a 4*60 shape. Semi-symetrical.
Currently--the thickest part of the rib--at the spars is 1-9/16" thick from the top of the rib to the bottom.
There is 1-1/16" between the spars. My wing tube is only .806" in diam.--so that leaves me with about .240" to fill in--if I install the tube in between the spars; as they are spaced right now.
Cord is 10.5"
I want to decrease the thickness to 1-5/16" and increase cord to 12.25"
That would space my spars so that my phenolic tube will fight tightly between them and not have to do a bunch of filling with balsa and epoxy.
I would be adding approx. 147sq.in. to the wing, via the lengthened cord. Total area would be approx. 1029sq.in.
Decreasing the thickness by approx. 36%--if my calculations are correct.
I don't know much technical stuff about airfoils; but, I would think that a thinner wing would need to fly faster to achieve the same lift. Maybe not--because of the added sq.in.??
At 1029sq.in--and weighing between 8--10 pounds-I don't think I'll have a problem with wing loading. I calculate it at 22.4oz/sq.ft--if the plane weighs 10 pounds.
If it weighs 8 pounds--then wing loading would be 17.9 oz/sq.ft.
