RE: 4* second plane and engine choice
glasrep... I have the 4*60 red ARF.... Yellow would be eaiser to see... I
have a Mag 91 4c and it flies it great and I like it... I used most of the
stock hardware except for the push rods.. They flex too much in the heat,
causing to retrim with temp. changes.. I went with some carbon fiber rods
that I had. I would use at least 4-40.. all else was stock... The build was
stright forward and fast, I just went per instructions but I did fiberglass
the wing joint, I don't think it's needed but I got in a habit of doing that.
I fly her pretty hard and have not had a problem that I did not cause:-)
I would use at least the Saito 82... She's an easy flyer and lands great!
Have fun and be safe!!
