RCU Forums - View Single Post - Engine starting Problem.
Old 05-29-2005 | 01:15 PM
tIANci's Avatar
tIANci
Default RE: Engine starting Problem.
Car engines do not like to idle long if you do not blip the throttle a little. This is most evident in the better performing 12 and 15 sized engines, the 21 sized ones can idle all day. Also, your low end might be a little rich, try leaning it off about 1/8 turn or just a little less than 1/8. Also, you can take the idle up a bit.
