RE: nitro ruslter help!!!
Sounds like you have the idle mixture too rich. As a diagnostic procedure try this: When at idle, try pinching the fuel line just ahead of the carb. If it dies immediately, then you need to richen (usually counter-clockwise on the idle mixture screw). If it speeds up quite a bit and then dies, it needs to be leaned (usually clockwise on the mixture screw). Hope that helps.
