RCU Forums - View Single Post - Giles elevator question
Old 05-30-2005 | 01:57 PM
rctom's Avatar
rctom
Default RE: Giles elevator question
You should call me first. I take care of problems that way. 817-430-0107. I'm here most of the time, even on memorial day.
It does matter that they are off, that elevator needs to be replaced which is what I would have done if you had called. This is a problem that happens with just about all builders of built-up tail surfaces, they build them on a flat surface and sometimes they have too much weight at the front and develop a twist.
TF
