RCU Forums - View Single Post - JET CAT IDLE PROBLEM
Old 05-30-2005 | 03:59 PM
John Redman
My Feedback: (8)
Default RE: JET CAT IDLE PROBLEM
This is a misaligned oil needle in the main oiling tube. Give me a call this week and I can walk you through the 20 second process to fix it. The engine will have to be removed from the aircraft and the front deckel cover (purple cover) removed. You can run it this way and it will not affect normal operation, it is just a small anoyance.
